[OpenLayers-Dev] SVN is currently broken
Erik Uzureau
erik.uzureau at metacarta.com
Thu Jul 5 20:18:22 EDT 2007
Hi Stephen,
Thanks for the heads up. I've updated those two references in trunk.
Can you try svn up again to see if the problem is fixed?
I tried building all three (full, lite, library) with the latest from
trunk and get no errors.
Then again, I tried building a couple hours ago and similarly had no
errors. Are you sure it's not maybe a missing file on your end?
Im out of the office in a few minutes but will try to look at this
again later tonight.
Erik
On 7/5/07, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Hi,
> I just did an update and ./build.py full
> Resolution pass 1...
> Importing: Openlayers/Layer.js
> Traceback (most recent call last):
> File "./build.py", line 18, in ?
> merged = mergejs.run(sourceDirectory, None, configFilename)
> File "../tools/mergejs.py", line 190, in run
> content = open(fullpath, "U").read() # TODO: Ensure end of line @ EOF?
> IOError: [Errno 2] No such file or directory: '../lib/Openlayers/Layer.js'
> It looks like these files might be the problem as they have OpenLayers
> spelled Openlayers (notice lower case L).
> OpenLayers/Layer/Markers.js: * @requires Openlayers/Layer.js
> OpenLayers/Renderer/SVG.js: * - <Openlayers.Renderer.Elements>
> -Steve
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
