[OpenLayers-Dev] SVN is currently broken
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jul 5 22:23:43 EDT 2007
Erik,
That fixed it and it's working fine again.
Thanks for the quick assist.
  -Steve
Erik Uzureau wrote:
> Hi Stephen,
> Thanks for the heads up. I've updated those two references in trunk.
> Can you try svn up again to see if the problem is fixed?
> I tried building all three (full, lite, library) with the latest from
> trunk and get no errors.
> Then again, I tried building a couple hours ago and similarly had no
> errors. Are you sure it's not maybe a missing file on your end?
> Im out of the office in a few minutes but will try to look at this
> again later tonight.
> Erik
> On 7/5/07, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>> Hi,
>> I just did an update and ./build.py full
>> Resolution pass 1...
>> Importing: Openlayers/Layer.js
>> Traceback (most recent call last):
>>    File "./build.py", line 18, in ?
>>      merged = mergejs.run(sourceDirectory, None, configFilename)
>>    File "../tools/mergejs.py", line 190, in run
>>      content = open(fullpath, "U").read() # TODO: Ensure end of line @
>> EOF?
>> IOError: [Errno 2] No such file or directory:
>> '../lib/Openlayers/Layer.js'
>> It looks like these files might be the problem as they have OpenLayers
>> spelled Openlayers (notice lower case L).
>> OpenLayers/Layer/Markers.js: * @requires Openlayers/Layer.js
>> OpenLayers/Renderer/SVG.js: *  - <Openlayers.Renderer.Elements>
>> -Steve
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
