[OpenLayers-Dev] Poor Image Quality
Bradley Mclain
bradleym06 at gmail.com
Tue Jul 10 21:37:16 EDT 2007
For some reason this is not working for me, I changed the settings in the
Mapfile and defined the OUTPUTFORMAT and then added the format:'image/png',
to my Openlayers folder. I even tried changing my mapfile to export as jpeg
so as to match Openayers but no luck.
Could it have something to do with that I am using the
MapServer.Untiledlayer function instead of a
WMS.Untiled layer?
On 7/10/07, Andrew Hughes <azza at lisasoft.com> wrote:
> Bart's correct... but just be warned.... jpeg is A LOT smaller is size
> than png-24. There's a reason why jpeg is the default in OpenLayers.
> --AH
> Bart van den Eijnden (OSGIS) wrote:
> OpenLayers uses jpeg by default for WMS layers, so change it in the
> constructor of your WMS.Untiled layer:
> 'format':'image/png', i.e.:
> baselayer0 = new OpenLayers.Layer.WMS.Untiled( "Standaard",
> "http://test.intranet.rijkswaterstaat.nl/services/geoservices/startkaart?" <http://test.intranet.rijkswaterstaat.nl/services/geoservices/startkaart?>,
> {layers: 'startkaart', 'format':'image/png', 'transparent':'TRUE'},
> {'numZoomLevels': 12, 'ratio':1, isBaseLayer: true} );
> Also check you have image/png mapped as a mimetype for PNG24 in your
> Mapserver MAP file (OUTPUTFORMAT section).
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Bradley Mclain <bradleym06 at gmail.com> <bradleym06 at gmail.com>
> Naar: OpenLayers ML <dev at openlayers.org> <dev at openlayers.org>
> Onderwerp: [OpenLayers-Dev] Poor Image Quality
> Datum: 10/07/07 05:07
> I am importing an image as an untiled Mapserver layer into OpenLayers and
> it is of extremely good quality but when it shows up in OpenLayers it's
> quality is terrible.The image when viewed through Mapserver is not as good
> as the original but it still much better than what it is showing up as in
> OpenLayers. I have my Mapserver image format as PNG24.
> Any ideas on what might be causing this and how to fix it?CheersBrad
> Dev mailing list
> Dev at openlayers.orghttp://openlayers.org/mailman/listinfo/dev
> Dev mailing list
> Regards,
> *Andrew Hughes*
> Software Engineer
> LISAsoft Pty. Ltd. (Adelaide)
> LISAsoft Pty. Ltd. <http://www.lisasoft.com> *ADELAIDE Office*
> <http://terrapages.net/mapbutton/RetrieveButtonServlet?buttonID=4>
> 38 Greenhill Road
> Wayville SA 5034
> Australia
> *Telephone +61 8 8272 1555*
> *Facsimile +61 8 8271 1199*
> *SYDNEY Office*
> <http://terrapages.net/mapbutton/RetrieveButtonServlet?buttonID=1>
> Suite 112 The Lower Deck
> Jones Bay Wharf
> 19-21 Pirrama Road
> Pyrmont NSW 2009 AUS
> *Telephone +61 2 8570 5060*
> *Facsimile +61 2 8570 5099*
> *MELBOURNE Office*
> <http://terrapages.net/mapbutton/RetrieveButtonServlet?buttonID=3>
> Level 7 520 Collins Street
> Melbourne VIC 3000
> Australia
> *Telephone +61 3 9629 1799*
> *Facsimile +61 3 9629 4955*
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070711/529b3475/attachment.html
More information about the Dev
