[OpenLayers-Dev] Poor Image Quality
Bradley Mclain
bradleym06 at gmail.com
Tue Jul 10 21:50:01 EDT 2007
Little update which might help shed some light on the matter. I saved that
particular layer and it is a PNG format
not PNG24 or jpeg, so somehow OpenLayers request to Mapserver is ignoring
the new formats.
I did WMS URL requests to Mapserver and it returns the correct formats.
On 7/11/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> For some reason this is not working for me, I changed the settings in the
> Mapfile and defined the OUTPUTFORMAT and then added the format:'image/png',
> to my Openlayers folder. I even tried changing my mapfile to export as jpeg
> so as to match Openayers but no luck.
> Could it have something to do with that I am using the MapServer.Untiledlayer function instead of a
> WMS.Untiled layer?
> On 7/10/07, Andrew Hughes <azza at lisasoft.com> wrote:
> > Bart's correct... but just be warned.... jpeg is A LOT smaller is size
> > than png-24. There's a reason why jpeg is the default in OpenLayers.
> > --AH
> > Bart van den Eijnden (OSGIS) wrote:
> > OpenLayers uses jpeg by default for WMS layers, so change it in the
> > constructor of your WMS.Untiled layer:
> > 'format':'image/png', i.e.:
> > baselayer0 = new OpenLayers.Layer.WMS.Untiled
> > ( "Standaard",
> > "http://test.intranet.rijkswaterstaat.nl/services/geoservices/startkaart?"
> > <http://test.intranet.rijkswaterstaat.nl/services/geoservices/startkaart?>,
> > {layers: 'startkaart', 'format':'image/png', 'transparent':'TRUE'},
> > {'numZoomLevels': 12, 'ratio':1, isBaseLayer: true} );
> > Also check you have image/png mapped as a mimetype for PNG24 in your
> > Mapserver MAP file (OUTPUTFORMAT section).
> > Best regards,
> > Bart
> > OSGIS, Open Source GIS
> > http://www.osgis.nl
> > --------- Oorspronkelijk bericht --------
> > Van: Bradley Mclain <bradleym06 at gmail.com> <bradleym06 at gmail.com>
> > Naar: OpenLayers ML <dev at openlayers.org> <dev at openlayers.org>
> > Onderwerp: [OpenLayers-Dev] Poor Image Quality
> > Datum: 10/07/07 05:07
> > I am importing an image as an untiled Mapserver layer into OpenLayers and
> > it is of extremely good quality but when it shows up in OpenLayers it's
> > quality is terrible.The image when viewed through Mapserver is not as good
> > as the original but it still much better than what it is showing up as in
> > OpenLayers. I have my Mapserver image format as PNG24.
> > Any ideas on what might be causing this and how to fix it?CheersBrad
> > Dev mailing list
> > Dev at openlayers.orghttp://openlayers.org/mailman/listinfo/dev
> > Dev mailing list
> > Regards,
> > *Andrew Hughes*
> > Software Engineer
> > LISAsoft Pty. Ltd. (Adelaide)
> > LISAsoft Pty. Ltd. <http://www.lisasoft.com> *ADELAIDE Office*
> > <http://terrapages.net/mapbutton/RetrieveButtonServlet?buttonID=4>
> > 38 Greenhill Road
> > Wayville SA 5034
> > Australia
> > *Telephone +61 8 8272 1555*
> > *Facsimile +61 8 8271 1199*
> > *SYDNEY Office*
> > <http://terrapages.net/mapbutton/RetrieveButtonServlet?buttonID=1>
> > Suite 112 The Lower Deck
> > Jones Bay Wharf
> > 19-21 Pirrama Road
> > Pyrmont NSW 2009 AUS
> > *Telephone +61 2 8570 5060*
> > *Facsimile +61 2 8570 5099*
> > *MELBOURNE Office*
> > <http://terrapages.net/mapbutton/RetrieveButtonServlet?buttonID=3>
> > Level 7 520 Collins Street
> > Melbourne VIC 3000
> > Australia
> > *Telephone +61 3 9629 1799*
> > *Facsimile +61 3 9629 4955*
> > Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070711/0c1ffd36/attachment.html
More information about the Dev
