[OpenLayers-Dev] Poor Image Quality
Bradley Mclain bradleym06 at gmail.com
Tue Jul 10 22:35:11 EDT 2007
Sorry for the triple reply but I managed to solve it by editing the
Mapserver/Untiled.js file to have default image type as png24.
On 7/11/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> Little update which might help shed some light on the matter. I saved that
> particular layer and it is a PNG format
>  not PNG24 or jpeg, so somehow OpenLayers request to Mapserver is ignoring
> the new formats.
> I did WMS URL requests to Mapserver and it returns the correct formats.
> On 7/11/07, Bradley Mclain < bradleym06 at gmail.com> wrote:
> > For some reason this is not working for me, I changed the settings in
> > the Mapfile and defined the OUTPUTFORMAT and then added the
> > format:'image/png', to my Openlayers folder. I even tried changing my
> > mapfile to export as jpeg so as to match Openayers but no luck.
> > Could it have something to do with that I am using the MapServer.Untiledlayer function instead of a
> > WMS.Untiled layer?
> > On 7/10/07, Andrew Hughes <azza at lisasoft.com> wrote:
> > >  Bart's correct... but just be warned.... jpeg is A LOT smaller is
> > > size than png-24. There's a reason why jpeg is the default in OpenLayers.
> > > --AH
> > > Bart van den Eijnden (OSGIS) wrote:
> > > OpenLayers uses jpeg by default for WMS layers, so change it in the
> > > constructor of your WMS.Untiled layer:
> > > 'format':'image/png', i.e.:
> > > baselayer0 = new OpenLayers.Layer.WMS.Untiled
> > > ( "Standaard",
> > > "http://test.intranet.rijkswaterstaat.nl/services/geoservices/startkaart?"
> > >  <http://test.intranet.rijkswaterstaat.nl/services/geoservices/startkaart?>,
> > > {layers: 'startkaart', 'format':'image/png', 'transparent':'TRUE'},
> > > {'numZoomLevels': 12, 'ratio':1, isBaseLayer: true} );
> > > Also check you have image/png mapped as a mimetype for PNG24 in your
> > > Mapserver MAP file (OUTPUTFORMAT section).
> > > Best regards,
> > > Bart
> > > OSGIS, Open Source GIS
> > > http://www.osgis.nl
> > > --------- Oorspronkelijk bericht --------
> > > Van: Bradley Mclain <bradleym06 at gmail.com> <bradleym06 at gmail.com>
> > > Naar: OpenLayers ML <dev at openlayers.org> <dev at openlayers.org>
> > > Onderwerp: [OpenLayers-Dev] Poor Image Quality
> > > Datum: 10/07/07 05:07
> > >  I am importing an image as an untiled Mapserver layer into OpenLayers and
> > >  it is of extremely good quality but when it shows up in OpenLayers it&#39;s
> > > quality is terrible.The image when viewed through Mapserver is not as good
> > > as the original but it still much better than what it is showing up as in
> > > OpenLayers. I have my Mapserver image format as PNG24.
> > >  Any ideas on what might be causing this and how to fix it?CheersBrad
> > > _______________________________________________
> > > Dev mailing list
> > > Dev at openlayers.orghttp://openlayers.org/mailman/listinfo/dev
> > > Dev mailing list
> > > Regards,
> > > *Andrew Hughes*
> > > Software Engineer
> > > LISAsoft Pty. Ltd. (Adelaide)
> > >    LISAsoft Pty. Ltd. <http://www.lisasoft.com>  *ADELAIDE Office*
> > >  <http://terrapages.net/mapbutton/RetrieveButtonServlet?buttonID=4>
> > > 38 Greenhill Road
> > > Wayville SA 5034
> > > Australia
> > > *Telephone +61 8 8272 1555*
> > > *Facsimile +61 8 8271 1199*
> > >  *SYDNEY Office*
> > >  <http://terrapages.net/mapbutton/RetrieveButtonServlet?buttonID=1>
> > > Suite 112 The Lower Deck
> > > Jones Bay Wharf
> > > 19-21 Pirrama Road
> > > Pyrmont NSW 2009 AUS
> > > *Telephone +61 2 8570 5060*
> > > *Facsimile +61 2 8570 5099*
> > >  *MELBOURNE Office*
> > >  <http://terrapages.net/mapbutton/RetrieveButtonServlet?buttonID=3>
> > > Level 7 520 Collins Street
> > > Melbourne VIC 3000
> > > Australia
> > > *Telephone +61 3 9629 1799*
> > > *Facsimile +61 3 9629 4955*
> > > Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070711/4b084278/attachment.html
More information about the Dev mailing list
