[OpenLayers-Dev] Hiding Layers from the Layer Switcher
Erik Uzureau
erik.uzureau at metacarta.com
Wed Jul 18 20:18:24 EDT 2007
off the cuff reply is that yes, the reason the noEvent thing is passed
is to prevent an infinite loop. I'll add this to my queue of tickets
to make.
Good one :-)
erik
On 7/18/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Wed, Jul 18, 2007 at 05:21:45PM -0400, Peterson Eric-EEP002 wrote:
> > I then run it in Firebug, set a breakpoint in updateLayerVisibility(),
> > and click my checkboxes in the LayerSwitcher. But the breakpoint is
> > never tripped ... The changelayer event is never being triggered.
> > I looked into the code a bit, and I think I may have found a bug in the
> > LayerSwitcher.js file (the latest trunk version has this issue as well
> > as 2.4). In the onInputClick() method, the 'changebaselayer' event is
> > being triggered when the base layer changes, but there's no
> > 'changelayer' event when an overlay layer changes. Should there be the
> > following line between 284 and 285?
> > this.layer.map.events.triggerEvent("changelayer");
> No -- the changelayer event should be fired by setVisibility.
> However, after you sent this email, I was reminded that I had
> established that this was explicitly set not to happen in the
> LayerSwitcher.js:
> layerEntry.layer.setVisibility(layerEntry.inputElem.checked, true);
> I never established why this was. Erik might have a better idea:
> Erik, can you remember why we don't fire the event in this case? It's a
> problem for the existing ticket (10something) on attribution, with a
> patch by penyaskito. I think we need to figure out how to fire an event
> here.
> Looking at it, it seems possible that firing an event would lead to
> an infinite loop. If that is the problem, we should discuss a resolution
> to that. If you can confirm that, and open a bug for 2.5, that would be
> great.
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
