[OpenLayers-Dev] OpenLayers dragging issue
Les Szklanny
lszklanny at where2getit.com
Fri Jul 20 10:38:00 EDT 2007
I created a simple demo using OL 2.4 and Scriptaculous 1.7.1 beta 3
showing a dragging problem, which I believe is caused by OpenLayers.
http://www.slippymap.com/kamap.html
Try to quickly drag the 'Powered by Oracle' image. If you are using FF
or Safari, the image gets disconnected from the cursor, but it drags
quite well on IE 6 and 7.
If I comment out the MouseDefaults or MousePosition controls, then
dragging becomes very smooth as one would expect. The two controls have
handlers that observe mouse movement.
Any idea how to fix or work around this problem?
Thx,
Les Szklanny
Where2GetIt
More information about the Dev
