[OpenLayers-Dev] OpenLayers dragging issue
Christopher Schmidt crschmidt at metacarta.com
Fri Jul 27 11:55:49 EDT 2007
On Fri, Jul 27, 2007 at 08:53:23AM -0500, Les Szklanny wrote:
> Les Szklanny wrote:
> > Hi,
> > I created a simple demo using OL 2.4 and Scriptaculous 1.7.1 beta 3
> > showing a dragging problem, which I believe is caused by OpenLayers.
> > http://www.slippymap.com/kamap.html
> > Try to quickly drag the 'Powered by Oracle' image.  If you are using
> > FF or Safari, the image gets disconnected from the cursor, but it
> > drags quite well on IE 6 and 7.
> > If I comment out the MouseDefaults or MousePosition controls, then
> > dragging becomes very smooth as one would expect.  The two controls
> > have handlers that observe mouse movement.
> Hi all and happy Friday :)
> I asked this question a week ago...
> Is there something I can add or clarify?   I'm lost how to handle this
> problem.
I don't have the problem on Firefox 2.0 on OS X.
Oh, I see -- you meant 'drag it over the map'. Yes. This is probably
because the event is stopped by the map when you mouse out. Search the
code for OpenLayers.Event.stop, return false;, etc.
However, in general, these things are there for a reason -- I can't
guarentee it, but it is possible that changing this behavior will result
in other parts of OpenLayers not working as expected.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
