[OpenLayers-Dev] Performance question
Lance Dyas
lancelot at inetnebr.com
Mon Jul 30 09:43:04 EDT 2007
Lorenzo Becchi wrote:
>> > The primary issues with supporting this are not issues that can be
>> > solved on the client side. WMS layers from the same server can be
>> told to composite on the WMserver ... if they were managed in the
>> layer switcher as separate layers the user would get the controls but
>> not the quick switch ... but much fewer images requested from the
>> servers... it is about creating a good illusion.
>> These comma separated layers could be listed individually or like
>> subfolders in a tree
> Actually quick switching from the same WMS server would be feasible if
> we allow the interface to move up and down wms layers inside the same
> OL layer.
> Then we just need to refresh the OL layer.
Layer shuffling( turning off a layer for example is instantaneous) as
they are stored as separate graphics client side is fast and even the
adding of a new layer to the mix is faster as the server is only
processing that one... but the server side composited, reordering or
exclusion of a layer will be slow as it is processing/re-rendering all
the combined layers.. its not "Quick" anymore. We get different benefits
> All this is still colliding with TileCache or ka-Map cache as it is
> make poor sense to store/cache all layer combinations from one server.
indubitably
> ciao
> Lorenzo
> Lance Dyas wrote:
>> Christopher Schmidt wrote:
>>> On Sat, Jul 28, 2007 at 02:29:13PM +0100, Ludwig M Brinckmann wrote:
>>>>> In general, I would advise against having 11 seperate layers on a
>>>>> map.
>>>>> It's possible that this really is neccesary, but in general, 11
>>>>> layers
>>>>> is more likely to confuse the user: You're the map maker, make some
>>>>> decisions about how the map should look, and combine some of the
>>>>> layers.
>>>> Well, I think there are many situations where one would want to
>>>> give a user,
>>>> which might not be the general public, a _lot_ of layers and I
>>>> would argue
>>>> that OL should should support this.
>> WMS layers from the same server can be told to composite on the
>> WMserver ... if they were managed in the layer switcher as separate
>> layers the user would get the controls but not the quick switch ...
>> but much fewer images requested from the servers... it is about
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
