[OpenLayers-Dev] Performance question
Lorenzo Becchi lorenzo at ominiverdi.com
Mon Jul 30 04:04:22 EDT 2007
> > The primary issues with supporting this are not issues that can be
> > solved on the client side.
> WMS layers from the same server can be told to composite on the WMserver
> ... if they were managed in the layer switcher as separate layers the
> user would get the controls but not the quick switch ... but much fewer
> images requested from the servers... it is about creating a good illusion.
> These comma separated layers could be listed individually or like
> subfolders in a tree
Actually quick switching from the same WMS server would be feasible if
we allow the interface to move up and down wms layers inside the same OL
layer.
Then we just need to refresh the OL layer.
All this is still colliding with TileCache or ka-Map cache as it is make
poor sense to store/cache all layer combinations from one server.
ciao
Lorenzo
> ______________________
Lance Dyas wrote:
> Christopher Schmidt wrote:
>> On Sat, Jul 28, 2007 at 02:29:13PM +0100, Ludwig M Brinckmann wrote:
>>>> In general, I would advise against having 11 seperate layers on a map.
>>>> It's possible that this really is neccesary, but in general, 11 layers
>>>> is more likely to confuse the user: You're the map maker, make some
>>>> decisions about how the map should look, and combine some of the
>>>> layers.
>>> Well, I think there are many situations where one would want to give
>>> a user,
>>> which might not be the general public, a _lot_ of layers and I would
>>> argue
>>> that OL should should support this.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
