[OpenLayers-Dev] WMC on WMSManager
Cameron Shorter
cameron.shorter at gmail.com
Tue Jul 31 22:58:09 EDT 2007
Lorenzo,
Good work.
I'm CCing Tom Kralidis who is/was/should be/.. the editor of the OWS
Context spec and has been very helpful with the Mapbuilder use of Context.
Tom should be able to add insight into upcoming Context terms. For
example, the visibility attribute has been earmarked for future versions
and is already implemented by Mapbuilder.
A good test of interoperability would be to export a Context document
from Mapbuilder then load it into Openlayers and visa-versa.
Lorenzo Becchi wrote:
> Tim, I do agree with all your suggestions.
> Actually I can just go on holidays and wait you to do the job for us,
> I'm sure it will be better that whatever I can do alone.
> I'll go on holidays tomorrow (15 days) but I'm available for the debate
> today.
> Let me know if you want to chat about it.
> #openlayers ?
> I think we can already debate about a timetable and see if and where I
> can help you to integrate your work.
> Let's try to see who else want to join (seems Erik has already something
> in his hands).
> I suggest to use your Wiki page to manage this:
> http://trac.openlayers.org/wiki/Future/MapContext
> see you later
> Lorenzo
> Tim Schaub wrote:
>> A few ideas:
>> It would be good to start working towards a JavaScript structure for the
>> map context. For OL, this structure would contain all relevant layer
>> information and the current map center/resolution. On the WMC side, we
>> should discuss how to standardize the extensions to WMC to account for
>> OL specific stuff.
>> This structure should be serialized/deserialized with a JSON parser.
>> http://dev.openlayers.org/sandbox/tschaub/geojson/lib/OpenLayers/Format/JSON.js
>> (for example - and you can do format.write(obj, pretty) too)
>> In addition to translating this structure into a WMC doc, we should be
>> able to translate it into a short string - though this will be lossy, it
>> can be used to replace the permalink logic.
>> All this could be handled by a control like OpenLayers.Control.Context
>> or OpenLayers.Control.ApplicationState. This control would use the JSON
>> format and a (yet to be built) WMC format.
>> I'll be working on this sort of stuff over the next couple months. I
>> look forward to collaborating.
>> Tim
>>> Click on the bottom-right button "WMC Exporter" to see a pop-up with the
>>> JSON code of the WMC.
>>> Naturally you can alter the map with WMSManager and the WMC "should" be
>>> updated.
>>> as you can see:
>>> - the structure is not a perfect WMC. I've took a look from the 1.1
>>> specs but there are things to be cleaned up.
>>> - some values are empty or null. Still have to decide if it make sense
>>> to use all of them. We can decide together which optional elements not
>>> to support.
>>> - I've added a "visibility" attribute to Layer object because WMC is not
>>> providing it. Some hint how to avoid this? I'm sure you understand how
>>> this is important for OL to define base or overlay layers.
>>> as you can't see:
>>> - not all values are dinamically set. Some are still hardcoded.
>>> there's another problem about attributes of Layers with multiple WMS
>>> layers inside. Which title, abstract to use? does it make sense to
>>> create a comma (or something else) separated list of values?
>>> I'm still not sure if the MapContext should be part of the OL.Map object
>>> or an external Tool.
>>> I'll go on with the external tool and hope to create soon a WMCParser to
>>> import WMCs.
>>> My hope was to offer something better before leaving for holidays but
>>> many meeting/debate/ecc at work delayed coding time.
>>> I'll leave in 2 days and be back for the third week of August. In the
>>> meantime I'll be available for debate about this solution.
>>> ciao
>>> Lorenzo
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>>> !DSPAM:4033,46adec84154021431913854!
>> Dev mailing list
> Dev mailing list
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
More information about the Dev
