[OpenLayers-Dev] WMC on WMSManager
Lorenzo Becchi lorenzo at ominiverdi.com
Tue Jul 31 06:21:35 EDT 2007
Tim, I do agree with all your suggestions.
Actually I can just go on holidays and wait you to do the job for us,
I'm sure it will be better that whatever I can do alone.
I'll go on holidays tomorrow (15 days) but I'm available for the debate
today.
Let me know if you want to chat about it.
#openlayers ?
I think we can already debate about a timetable and see if and where I
can help you to integrate your work.
Let's try to see who else want to join (seems Erik has already something
in his hands).
I suggest to use your Wiki page to manage this:
http://trac.openlayers.org/wiki/Future/MapContext
see you later
Lorenzo
Tim Schaub wrote:
> A few ideas:
> It would be good to start working towards a JavaScript structure for the
> map context.  For OL, this structure would contain all relevant layer
> information and the current map center/resolution.  On the WMC side, we
> should discuss how to standardize the extensions to WMC to account for
> OL specific stuff.
> This structure should be serialized/deserialized with a JSON parser.
> http://dev.openlayers.org/sandbox/tschaub/geojson/lib/OpenLayers/Format/JSON.js
> (for example - and you can do format.write(obj, pretty) too)
> In addition to translating this structure into a WMC doc, we should be
> able to translate it into a short string - though this will be lossy, it
> can be used to replace the permalink logic.
> All this could be handled by a control like OpenLayers.Control.Context
> or OpenLayers.Control.ApplicationState.  This control would use the JSON
> format and a (yet to be built) WMC format.
> I'll be working on this sort of stuff over the next couple months.  I
> look forward to collaborating.
> Tim
>> Click on the bottom-right button "WMC Exporter" to see a pop-up with the
>> JSON code of the WMC.
>> Naturally you can alter the map with WMSManager and the WMC "should" be
>> updated.
>> as you can see:
>> - the structure is not a perfect WMC. I've took a look from the 1.1
>> specs but there are things to be cleaned up.
>> - some values are empty or null. Still have to decide if it make sense
>> to use all of them. We can decide together which optional elements not
>> to support.
>> - I've added a "visibility" attribute to Layer object because WMC is not
>> providing it. Some hint how to avoid this? I'm sure you understand how
>> this is important for OL to define base or overlay layers.
>> as you can't see:
>> - not all values are dinamically set. Some are still hardcoded.
>> there's another problem about attributes of Layers with multiple WMS
>> layers inside. Which title, abstract to use? does it make sense to
>> create a comma (or something else) separated list of values?
>> I'm still not sure if the MapContext should be part of the OL.Map object
>> or an external Tool.
>> I'll go on with the external tool and hope to create soon a WMCParser to
>> import WMCs.
>> My hope was to offer something better before leaving for holidays but
>> many meeting/debate/ecc at work delayed coding time.
>> I'll leave in 2 days and be back for the third week of August. In the
>> meantime I'll be available for debate about this solution.
>> ciao
>> Lorenzo
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
>> !DSPAM:4033,46adec84154021431913854!
> Dev mailing list
More information about the Dev mailing list
