[OpenLayers-Dev] WMC on WMSManager
Erik Uzureau erik.uzureau at metacarta.com
Mon Jul 30 17:10:17 EDT 2007
Note that I started working on this a while ago for the
history/browser control. Please keep me in the loop for any/all
discussions about this js serialization bit.
On 7/30/07, Tim Schaub <tschaub at openplans.org> wrote:
> Hey Lorenzo-
> Lorenzo Becchi wrote:
> > Nothing to be proud of but I've published a first step to support Web
> > Map Context inside OpenLayers:
> > http://tinyurl.com/2b6z6r
> Looks like you've been busy.
> A few ideas:
> It would be good to start working towards a JavaScript structure for the
> map context.  For OL, this structure would contain all relevant layer
> information and the current map center/resolution.  On the WMC side, we
> should discuss how to standardize the extensions to WMC to account for
> OL specific stuff.
> This structure should be serialized/deserialized with a JSON parser.
> http://dev.openlayers.org/sandbox/tschaub/geojson/lib/OpenLayers/Format/JSON.js
> (for example - and you can do format.write(obj, pretty) too)
> In addition to translating this structure into a WMC doc, we should be
> able to translate it into a short string - though this will be lossy, it
> can be used to replace the permalink logic.
> All this could be handled by a control like OpenLayers.Control.Context
> or OpenLayers.Control.ApplicationState.  This control would use the JSON
> format and a (yet to be built) WMC format.
> I'll be working on this sort of stuff over the next couple months.  I
> look forward to collaborating.
> Tim
> > Click on the bottom-right button "WMC Exporter" to see a pop-up with the
> > JSON code of the WMC.
> > Naturally you can alter the map with WMSManager and the WMC "should" be
> > updated.
> > as you can see:
> > - the structure is not a perfect WMC. I've took a look from the 1.1
> > specs but there are things to be cleaned up.
> > - some values are empty or null. Still have to decide if it make sense
> > to use all of them. We can decide together which optional elements not
> > to support.
> > - I've added a "visibility" attribute to Layer object because WMC is not
> > providing it. Some hint how to avoid this? I'm sure you understand how
> > this is important for OL to define base or overlay layers.
> > as you can't see:
> > - not all values are dinamically set. Some are still hardcoded.
> > there's another problem about attributes of Layers with multiple WMS
> > layers inside. Which title, abstract to use? does it make sense to
> > create a comma (or something else) separated list of values?
> > I'm still not sure if the MapContext should be part of the OL.Map object
> > or an external Tool.
> > I'll go on with the external tool and hope to create soon a WMCParser to
> > import WMCs.
> > My hope was to offer something better before leaving for holidays but
> > many meeting/debate/ecc at work delayed coding time.
> > I'll leave in 2 days and be back for the third week of August. In the
> > meantime I'll be available for debate about this solution.
> > ciao
> > Lorenzo
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> > !DSPAM:4033,46adec84154021431913854!
> Dev mailing list
More information about the Dev mailing list
