[OpenLayers-Dev] IE
Lorenzo Becchi lorenzo at ominiverdi.com
Tue Jun 5 07:02:49 EDT 2007
thanks a lot, again, Lance, your is the first debugger help to WMSManager.
I feel that the solution should be trivial, I just have to pass through
my emotional wall against IE and try some solutions.
Nobody wants 80kb more than what we already have to just to do a better
parsing for IE.
The behavior is just like (IE in first person): sometimes I have a good
feeling with this  XML sometime I don't.
In the second case:
var text = ajaxRequest.responseText;
var xml = OpenLayers.parseXMLString(text);
if(typeof xml=='object'){
    IE enters but the object is empty
    xml.getElementsByTagName('whatever') = return no items
I'm trying to find the system to let IE digest this XML.
ciao
Lorenzo
Lance Dyas wrote:
> Lorenzo Becchi wrote:
>> Hope somebody can help me solving IE XML parsing problem
>> (WMSManager.js line 862) and Safari select issue (WMSManager.js line
>> 674).
>> Otherwise I'll go on "crying alone"
> The true horror of it is. IE has very poor xml parsing...in specific
> NameSpaces and
> Character Encodings are munged...and while there is "XML for <Script>"
> a javascript
> library which can for the most part by pass it.. well it adds a
> minimum of 80kb to your
> solution and over the web... that is quite a cost
More information about the Dev mailing list
