[OpenLayers-Dev] Problems Mixing WMS, Google, and Vector Layers
Christopher Schmidt
crschmidt at metacarta.com
Wed Jun 13 13:51:28 EDT 2007
On Wed, Jun 13, 2007 at 01:45:37PM -0400, Peterson Eric-EEP002 wrote:
> The difference between the Vector layer points and Marker layer markers
> seems to be in vertical position (latitude) only - the lines appear
> either too high or too low on the Google map relative to the markers.
> Horizontal position (longitude) seems to be correct.
Yep.
http://trac.openlayers.org/ticket/658
"Vector layer does not work with Google"
http://svn.openlayers.org/sandbox/crschmidt/slowvector/ adds support for
the SVG renderer to work on Google.
Something solving this problem will likely make it into 2.5. In the
meantime, working against the slowvector sandbox should fix this for
you, though I haven't checked it switching back and forth between Google
and WMS.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
