[OpenLayers-Dev] Problems Mixing WMS, Google, and Vector Layers
Peterson Eric-EEP002
Eric.Peterson at motorola.com
Wed Jun 13 15:16:49 EDT 2007
Okay, glad to know that's a known issue. I know 2.4 was just released,
but is there a tentative release schedule for 2.5?
Another issue I've observed with differences between WMS and Google ...
Maybe there's already an open ticket on it as well.
I've got a set of markers and one popup box for each marker, with
mouseover/mouseout events for the marker triggering show()/hide() calls
to the corresponding popup.
This all works fine and dandy under WMS, but it doesn't work with
Google. I get strange errors when I mouseover one of my markers, and the
popup never appears.
I don't have a stack trace handy, but I'll grab one the next time I've
got my test case setup.
-eP
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Wednesday, June 13, 2007 1:51 PM
To: Peterson Eric-EEP002
Cc: dev at openlayers.org
Subject: Re: [OpenLayers-Dev] Problems Mixing WMS, Google, and Vector
Layers
On Wed, Jun 13, 2007 at 01:45:37PM -0400, Peterson Eric-EEP002 wrote:
> The difference between the Vector layer points and Marker layer
> markers seems to be in vertical position (latitude) only - the lines
> appear either too high or too low on the Google map relative to the
markers.
> Horizontal position (longitude) seems to be correct.
Yep.
http://trac.openlayers.org/ticket/658
"Vector layer does not work with Google"
http://svn.openlayers.org/sandbox/crschmidt/slowvector/ adds support for
the SVG renderer to work on Google.
Something solving this problem will likely make it into 2.5. In the
meantime, working against the slowvector sandbox should fix this for
you, though I haven't checked it switching back and forth between Google
and WMS.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
