[OpenLayers-Dev] bbox approximations for non-base layers
mario.beccia at tiscali.it
Tue Jun 26 14:39:42 EDT 2007
Hi all,
this is my first post to the list and I'm still experiencing with
openlayers, so I hope I'm not posting something irrelevant ;-)
I'm trying to build up a system which is making use of openlayers +
tilecache + GeoServer.
I'm experiencing a lot of problems with tilecache, which is refusing
to provide non-base layers correctly when I'm using zoom levels
different than 1.
The messages I get in the log are about not being able to calculate
the tile coordinates and/or saying that the tile is out of the layer
scope.
After a bit of debugging, I discovered that OpenLayers is sending the
bbox with different approximation levels if the layer is a base layer
or if it is an overlay.
For the same layer (same zoom level, same conditions, same properties
in the openlayers creation js, only difference is the "baseLayer"
flag), OpenLayers is sending the following request if it is a base
layer (I paste the request for 1 tile in the layer, it happens for
almost all the tiles...):
192.168.115.1 - - [26/Jun/2007:09:35:41 -0700] "GET
/tilecache/tilecache.py?LAYERS=basic&FORMAT=image%
2Fpng&SERVICE=WMS&VERSION=1.1.1
&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.
se_inimage&SRS=EPSG%3A4326&BBOX=-90%2C0%2C0%2C90&WIDTH=256&HEIGHT=256
HTTP/1.1" 200 4813
If I make it a non base layer, the request it generates for the same
tile is:
192.168.115.1 - - [26/Jun/2007:09:32:21 -0700] "GET
se_inimage&SRS=EPSG%3A4326&BBOX=-90%2C-0.175781%2C0%2C89.
824219&WIDTH=256&HEIGHT=256 HTTP/1.1" 500 727
As you'll notice, the bbox is different in the second request: instead
of (-90,0,0,90), openlayers sent (-90,-0.175781, 0,89.824219).
Another example for a different tile:
Base layer:
se_inimage&SRS=EPSG%3A4326&BBOX=-180%2C0%2C-90%
2C90&WIDTH=256&HEIGHT=256 HTTP/1.1" 200 3004
Non base layer:
se_inimage&SRS=EPSG%3A4326&BBOX=-180%2C-0.175781%2C-90%2C89.
Thie time the bbox in the first request was (-180,0,-90, 90), whereas
it becomes (-180, -0.175781,-90, 89.824219) for a non base layer.
Digging in the code, my understanding is that when a tile request for
a non-base layer must be produced, OpenLayers projects the layer coords
in the baseLayer srs. Even if the layers share the same srs, the
calculation is made anyway and an approximation error is produced (I'm
using a Linux FC5 + FireFox 2.0.0.4, but I don't think there would be a
huge difference with other os/browser combinations).
While may not be a problem with a normal wms, it becomes so when
something like tilecache (which is making some additional calculations
on tile requests) is put in the middle. Tilecache contains a
"threshold" for float values comparison, but I don't think that
adjusting it from 0.0001 (default value) to 0.1 (needed to work around
the approximation errors) would be a good solution (we lose too much in
terms of precision...).
The solution I'm using is to disable the reprojection on the
transparent layers (using the reproject flag), and it seems to work
fine.
Is this correct or am I missing something else?
M.
_______________________________________________________
Naviga e telefona senza limiti con Tiscali
Scopri le promozioni Tiscali Adsl: navighi e telefoni senza canone Telecom
http://abbonati.tiscali.it/adsl/
More information about the Dev
