[OpenLayers-Dev] bbox approximations for non-base layers
Christopher Schmidt crschmidt at metacarta.com
Tue Jun 26 16:12:17 EDT 2007
On Tue, Jun 26, 2007 at 08:39:42PM +0200, mario.beccia at tiscali.it wrote:
> The solution I'm using is to disable the reprojection on the
> transparent layers (using the reproject flag), and it seems to work
> fine.
> Is this correct or am I missing something else?
Nope, you're correct. It's in the TileCache documentation, though I
guess it's not clear enough, since it's the most FAQ that I get:
"If you are using TileCache for overlays, you should set the 'reproject'
option on the layer to 'false'."
 -- http://tilecache.org/readme.html
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
