[OpenLayers-Dev] SVG flip Y value
Domenico Febbo
domenico.febbo at gmail.com
Fri Jun 29 06:05:20 EDT 2007
Into SVG.js @ row 241 you have this method:
createRoot: function() {
var id = this.container.id + "_root";
var root = this.nodeFactory(id, "g");
// flip the SVG display Y axis upside down so it
// matches the display Y axis of the map
root.setAttributeNS(null, "transform", "scale(1, -1)");
return root;
I don't understand what means the flip transformation for every Y value.
This trasformation flips every Y value of an SVG object and you don't
have bat effect on a circle or a point because that are "simmetric" on
Y axis, but for a "text" element (see spech here [1])
You have a bad flip effect.
Why you don't flip only coordinates value of the center of gravity?
[1] http://www.w3.org/TR/SVG/text.html#TextElement ;
thanks to All
Domenico
More information about the Dev
