[OpenLayers-Dev] ButtonBase code review
Cameron Shorter cameron.shorter at gmail.com
Sat Mar 3 06:13:44 EST 2007
Olivier,
If you are addressing my comments, could you please go through the list
and reply to each comment with what you have done. Eg:
 > Line 10 Suggest that you use "case" instead of "if .. else if .. else
if".
Done as suggested.
 > Line 20 Suggest that you use "case" instead of "if .. else if .. else
if".
Not done. I prefer using "if .. else if .." because in this case there
is only 3 cases and the use of "case" doesn't add any value
Inserting comments ensures I can be more effective in my second review.
Comments follow:
Regarding EditingAttributes and Buttons and Controls:
This is a discussion that probably should be discuss further than just
this code review, but you have identified an interesting problem: How
should we handle tools which trigger popups? (In OpenLayers, popups are
treated as controls).
I suggest we have 2 classes. An AttributeList control and a Query
button. The Query button creates and stores the AttributeList control
when the button is initialised, and the AttributeList is rendered when
the Query button is actioned (by mouseClick).
A web will need to be able to override the AttributeList defaults -
something like:
queryButton.attributeList.setParams([width:200, height:100]);
I suggest renaming EditingListener to EditingButton.
EditingAttributes should really be called Query or QueryAttributes as
(as far as I can tell, it doesn't allow Editing of attributes. I realize
that we use this name incorrectly in the Vector branch. A
EditingAttributes button should extend the QueryAttributes button and
should be a seperately selectable button.
There are lots of hard coded values in EditAttributes. I realise that
these come from the vector branch, and that I'm responsible for many of
them. At some point, these should be cleaned up.
olivier.terral wrote:
> Hi
> I've made a lot of modifications like you've said cameron,
> But I'm in front of a little problem, for EditingAttributes I've moved
> in a button code so It's not a control yet, because there is a
> conflict between the button div and the control div
> so I'm not sure if  it's in  accordance  with OL philosophy.
> Have a look please.
> Next episode, the NoButton.js file, coming back soon
> bye
> Cameron Shorter a écrit :
>> Olivier,
>> I have spent an hour or so reviewing your code in
>> http://trac.openlayers.org/log/sandbox/oterral/ButtonBar/vector/lib/OpenLayers/.
>> Overall, you have done a pretty good job. Ideally I'd like to spend
>> more, so they are sure to be things I've missed.
>> Chris, I hope you will add comments too, especially about names of
>> classes. Eg, What should we call the base Button/Tool class? I'm
>> inclined to call it Button.js.
>> Minor: You have a few tab chars. Change them to spaces.
>> You have created tools in the directories:
>> lib/OpenLayers/MouseListener/ and
>> lib/OpenLayers/MouseListener/EditingListener
>> I think the classes and directory structure should be renamed to
>> emphasize  the fact that you are creating Button Tools. Rename
>> MouseListener to Tool or Button, probably Button.
>> DragPan currently inherits from MouseListener, but MouseListener
>> doesn't contain empty parameters for id, imageOn, imageOff, etc.
>> We should have a base Button class that all the Buttons/Tools inherit
>> from. We have 2 options:
>> 1. MouseListener has child Button which has children DragPan, ZoomIn,
>> etc.
>> 2. MouseListener is renamed to Button, Button has children DragPan,
>> ZoomIn, ...
>> I prefer option 2. There will be Tools which don't have an icon and
>> are always on (Eg, mouseTrack tool). I suggest we create a type
>> "NoButton" type which can only be turned on/off from the program, not
>> via operator interaction. They will default to on.
>> Button will need null parameters for id, imageOn, imageOff, etc.
>> Button should also contain a param for cursorIconType. Ie, when the
>> tool is selected, the cursor type can change from an arrow, to a box,
>> to something else. You should be able to find examples in the
>> Mapbuilder code. I think it is in the MouseHander.js code.
>> Buttonbar.js (version 2281):
>> Why is X and Y initialised above the "inherit" braces? To be
>> consistent they should be initialised with the rest of the variables.
>> Buttonbar.js:
>> Please add jsdoc comments to all functions. It makes it much easier
>> to review. :)
>> Don't worry if your English has a French flavour to it. Us
>> mono-language speakers are generally very forgiving. So long as your
>> writing is understandable, then that is good. Someone else will clean
>> up the comments later if there is a problem.
>> Buttonbar.addTools line 54:
>> Minor comment: When looping over an array with length>=0, I suggest
>> using "for" instead of "while". This should be cleaner than the
>> "if,while" statements you have starting at line 54.
>> for(var i=0;i<tools.length;i++){...}
>> Buttonbar.addTools line 78:
>> Minor: This block loops through all the current this.tools. I suggest
>> that it only loop through the recently added tools. Ie, loop through
>> tools. Why not move the code into the block above (ie from line 54).
>> Buttonbar._addButton:
>> The properties of btn should be moved into the base Button class,
>> currently called MouseListener.
>> This means that the majority of _addButton will disappear.
>> I expected to see logic to ensure that one of the radio buttons is
>> always selected.
>> By default, the first radioButton added should be selected.
>> Why register for mouseup event on the button? It is not used. You can
>> also remove buttonUp() function.
>> Buttonbar.setTool:
>> You only seem to be catering for radioButton and button types. What
>> about a twoState button?
>> I suggest code like:
>> switch(tool.type)
>>  case "radioButton":
>>    break;
>>  default:
>>    tool.doSelect();
>> Buttonbar._swapButtonImg:
>> The logic for rendering a button should be moved into the base button
>> object, at the moment this is MouseListener.js.
>> An object should be responsible for drawing itself.
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5011
Mob: +61 (0)419 142 254
More information about the Dev mailing list
