[OpenLayers-Dev] [OpenLayers-Users] associating events to
geometries
Eric Lemoine
Eric.Lemoine at camptocamp.com
Tue Mar 20 07:36:31 EDT 2007
> > On 3/19/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> > > On Mon, Mar 19, 2007 at 11:40:22AM +0100, Eric Lemoine wrote:
> > > > Hello
> > > > I'd like to associate events to geometries. With the old vector branch
> > > > I did that using
> > > > feature.geometry.registerEventCallback('mouseover', null, callback);
> > > > but the registerEventCallback() no longer exists in the new vector tree.
> > > Have a look at http://openlayers.org/dev/examples/openmnnd.html , and
> > > the SelectFeature control. (In this case, the 'move' callback).
> > Good. Now I also need to handle 'mouseout' events, and I cannot find
> > an appropriate callback for mouseout...
> I just figured that using the SelectFeature control with the 'move'
> callback isn't the same as using registerEventCallback() with
> 'mouseover' as I used to do. Indeed, when using SelectFeature with
> 'move' the callback is called each time the mouse pointer starts
> moving on the feature. I don't want that. I want an event on
> 'mouseover' and another one on 'mouseout', not tons of events if the
> mouse pointer moves on the feature.
Christopher,
I changed my application code as follows to define mouseover and
mouseout callbacks:
var ctl = new OpenLayers.Control.SelectFeature(
pointLayer,
{ callbacks:
'over': mouseoverCallback,
'out': mouseoutCallback
ctl.handler.mouseover = function(evt) {
OpenLayers.Handler.Select.prototype.select.call(ctl.handler, 'over', evt);
ctl.handler.mouseout = function(evt) {
OpenLayers.Handler.Select.prototype.select.call(ctl.handler, 'out', evt);
and it works good :-)
However, I think these callbacks should be defined in the OpenLayers
lib - it's a bit tough to put that burden on the user, isn't it?
See attached patch.
Index: /home/elemoine/workspace/openlayers/lib/OpenLayers/Handler/Select.js
--- /home/elemoine/workspace/openlayers/lib/OpenLayers/Handler/Select.js
(revision 2816)
+++ /home/elemoine/workspace/openlayers/lib/OpenLayers/Handler/Select.js
(working copy)
@@ -62,6 +62,22 @@
mouseup: function(evt) {
return this.select('up', evt);
+ * @param {Object} evt
+ mouseover: function(evt) {
+ return this.select('over', evt);
+ mouseout: function(evt) {
+ return this.select('out', evt);
* Capture double-clicks.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
Property changes on: /home/elemoine/workspace/openlayers
___________________________________________________________________
+ .project
--- /home/elemoine/workspace/openlayers/lib/OpenLayers/Handler/Select.js (revision 2816)
+++ /home/elemoine/workspace/openlayers/lib/OpenLayers/Handler/Select.js (working copy)
@@ -62,6 +62,22 @@
More information about the Dev
