[OpenLayers-Dev] GML Layers is no more visible in vector
sandbox revision 2823
Christine Spietz
spietz at fh-bingen.de
Thu Mar 22 10:57:43 EDT 2007
Hi Christopher,
I clicked the right mouse button on file Map.js and looked at properties
http://svn.openlayers.org/trunk/openlayers/lib/OpenLayers/Map.js is the path
of my Map.js and I know that the line is empty.
I included the libs with <script src="lib/OpenLayers.js" />
and in folder lib are the libs of the actual OpenLayers trunk :-(
I did a new checkout of the actual version (revision 2846) but still the
same error.
Regards
Christine
----- Original Message -----
From: "Christopher Schmidt" <crschmidt at metacarta.com>
To: "Christine Spietz" <spietz at fh-bingen.de>
Cc: <dev at openlayers.org>
Sent: Thursday, March 22, 2007 2:27 PM
Subject: Re: [OpenLayers-Dev] GML Layers is no more visible in vector
> On Thu, Mar 22, 2007 at 12:36:22PM +0100, Christine Spietz wrote:
>> Hi again,
>> Also I 'm still getting the curios error:
>> >>OpenLayers.MouseListener.MouseDefaults is not a constructor
>> >>var mouseListener = new OpenLayers.MouseListener.MouseDefaults();
>> >>in Map.js line 229.
>> I'm really convinced that I do not use the code which causes the error,
>> so
>> I guessed it was an error in OpenLayers. But this also seems not to be
>> the
>> case....
> Line 229 in Map.js is empty in SVN. Your Map.js is not the same as
> http://svn.openlayers.org/trunk/openlayers/lib/OpenLayers/Map.js .
> disciplina:~/world_factbk/openlayers/lib/OpenLayers crschmidt$ svn info
> Map.js
> Path: Map.js
> URL: http://svn.openlayers.org/trunk/openlayers/lib/OpenLayers/Map.js
> If you run svn info on your Map.js file, I expect you will find that it
> does not have the above in the "URL" field of the output.
> Please try checking out a *fresh* copy of OpenLayers from SVN, and
> report if you are still having the same problems with the MouseListener.
> Regards,
> Christopher Schmidt
> MetaCarta
More information about the Dev
