[OpenLayers-Dev] feature event / highlight a feature
Christopher Schmidt crschmidt at metacarta.com
Fri Mar 30 08:45:36 EDT 2007
On Fri, Mar 30, 2007 at 02:12:21PM +0200, Christine Spietz wrote:
> Hi,
> I'm working with the actual trunk
> (http://svn.openlayers.org/trunk/openlayers/lib) and try to register an
> event on the features which are contained in a WFS-Layer.
> I want the feature to be highlighted/selected if a click-event happens on
> the feature. If the click-event happens on another feature, this feature
> should be highlighted and the previous feature should not be highlighted
> anymore.
> So the whole time only ONE feature is highlighted, if a click-event appears
> on this feature.
> Are there posibilities to do this with the actual trunk-code of OpenLayers?
See http://openlayers.org/dev/examples/select-feature.html
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
