[OpenLayers-Dev] feature event / highlight a feature
Christine Spietz
spietz at fh-bingen.de
Fri Mar 30 12:04:34 EDT 2007
Hi Christopher,
I've looked at the link (thanks for hint), but I think that this
unfortunately can not solve my problem.
In the example is a vector-Layer and I'm able to paint polygons in the
Vector-layer and then select them.
But I do not only want to paint polygons, I want to paint "real" features
like:
<gml:featureMember>
<myFeature>
<gml:boundedBy>
<gml:Box srsName="epsg:31467">
<gml:coordinates>3408164.712000,5507840.904000
3408614.729000,5508072.195000</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<myGeometry>
<gml:MultiPolygon srsName="epsg:31467">
<gml:polygonMember>
<gml:Polygon>
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>3408448.251000,5507873.652000 3408453.120000,5507855.352000
3408530.457000,5507875.125000 3408614.729000,5507917.478000
3408447.294000,5507873.301000 3408448.251000,5507873.652000
</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
<gml:innerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>3408423.685000,5507944.168000 3408410.433000,5507944.200000
3408361.516000,5507945.163000 3408316.234000,5507938.273000
3408311.640000,5507948.625000 3408307.446000,5507959.118000
3408315.911000,5507959.986000 3408362.976000,5507962.503000
3408414.480000,5507959.093000 3408423.685000,5507944.168000
</gml:coordinates>
</gml:LinearRing>
</gml:innerBoundaryIs>
</gml:Polygon>
</gml:polygonMember>
</gml:MultiPolygon>
</ms:myGeometry>
<myID>0026</myID>
</myFeature>
</gml:featureMember>
I can readout the coordinates of my features write them in a polygonfeature
and draw the polygons in the map in this way:
var pointList = [];
oModel = document.getElementById("myModel");
instance = oModel.getInstanceDocument("nameOfInstance");
linearRingArray=instance .getElementsByTagName("LinearRing");
if(linearRingArray.length>1){
for (auja=0;auja<linearRingArray.length;auja++){
if(linearRingArray[auja].childNodes.length>1){
koord= linearRingArray[auja].childNodes[1].firstChild.nodeValue;
koords= koord.split(" ");
if(koords.length>1){
for(aufein=0;aufein<koords.length;aufein++){
finalKoord= koords[aufein] ;
finalKoordFeld= finalKoord.split(",");
if (finalKoordFeld.length==2){
newPoint = new
OpenLayers.Geometry.Point(finalKoordFeld[0],finalKoordFeld[1]);
pointList.push(newPoint);
linearRing = new OpenLayers.Geometry.LinearRing(pointList);
polygonFeature = new OpenLayers.Feature.Vector(new
OpenLayers.Geometry.Polygon([linearRing]));
polygonLayer.addFeatures([polygonFeature]);
pointList= [];
drawControls = {
select: new OpenLayers.Control.SelectFeature(polygonLayer),
hover: new OpenLayers.Control.SelectFeature(polygonLayer,{hover: true})
for(key in drawControls) {
map.addControl(drawControls[key]);
var control = drawControls[key];
control.activate();
BUT:
I have a selectbox with all featureIds in my form (Attribute myID of the
featureMembers).If I click on the feature in the map, then the feature
should highlight and the id should be selected in selectbox.And in the other
direction: if user checks a special id in the selectbox, the feature in the
map should be highlighted.
So what I need is at least
- the possibility to get the Id of the selected feature, if the polygon in
the map is selected
- to select/highlight a feature in the map not only by click but also by id
Any ideas?
Christine
----- Original Message -----
From: "Christopher Schmidt" <crschmidt at metacarta.com>
To: "Christine Spietz" <spietz at fh-bingen.de>
Cc: <dev at openlayers.org>
Sent: Friday, March 30, 2007 2:45 PM
Subject: Re: [OpenLayers-Dev] feature event / highlight a feature
> On Fri, Mar 30, 2007 at 02:12:21PM +0200, Christine Spietz wrote:
>> Hi,
>> I'm working with the actual trunk
>> (http://svn.openlayers.org/trunk/openlayers/lib) and try to register an
>> event on the features which are contained in a WFS-Layer.
>> I want the feature to be highlighted/selected if a click-event happens on
>> the feature. If the click-event happens on another feature, this feature
>> should be highlighted and the previous feature should not be highlighted
>> anymore.
>> So the whole time only ONE feature is highlighted, if a click-event
>> appears
>> on this feature.
>> Are there posibilities to do this with the actual trunk-code of
>> OpenLayers?
> See http://openlayers.org/dev/examples/select-feature.html
> Regards,
> Christopher Schmidt
> MetaCarta
More information about the Dev
