[OpenLayers-Dev] feature event / highlight a feature
Tim Schaub
noreply at geocartic.com
Fri Mar 30 13:44:45 EDT 2007
Hello Christine-
Christine Spietz wrote:
> In the example is a vector-Layer and I'm able to paint polygons in the
> Vector-layer and then select them.
> But I do not only want to paint polygons, I want to paint "real" features
> like:
> <gml:featureMember>
> ... GML nonsense
> </gml:featureMember>
If you want use GML to create vector features see:
http://openlayers.org/dev/examples/gml-layer.html
and
http://openlayers.org/dev/examples/GMLParser.html
The first example uses a Layer.GML - a subclass of Layer.Vector. With
the GML layer, you construct it with a title and the path to your GML.
All the features in the GML will be added to your layer.
The second example uses the Format.GML - a GML parser. In this example,
you can see how to construct a Format.GML and call the read method to
get an array of features. Then you can do whatever you want with these
features (like add them to a vector layer to have them displayed).
Hope that helps,
Tim
More information about the Dev
