[OpenLayers-Dev] select-feature.html on FF 2.0.0.3
Eric Lemoine
Eric.Lemoine at camptocamp.com
Tue May 1 07:19:15 EDT 2007
On 4/26/07, Eric Lemoine <Eric.Lemoine at camptocamp.com> wrote:
> Hi,
> I've just switched to Ubuntu Feisty, which comes with Firefox 2.0.0.3.
> So far, life is sweet. Life gets harder when you point your browser to
> <http://www.openlayers.org/dev/examples/select-feature.html>. You
> cannot draw a polygon. Actually the polygon gets drawn but it doesn't
> get displayed. If I go to another FF tab and come back the polygon is
> displayed! The "select polygon on click" and "select polygon on hover"
> do not work at all.
> It sounds like an SVG issue!
> Is anyone able to reproduce the problem?
The problem is FF Feisty-specific. FF 2.0.0.3 from mozilla.org doesn't
have any problem.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
