[OpenLayers-Dev] select-feature.html on FF 2.0.0.3
Cameron Shorter
cameron.shorter at gmail.com
Wed May 2 19:07:37 EDT 2007
Yes Eric, I can confirm that I have the same problems on Ubuntu with the
same configuration.
Interesting, there are no JS errors.
From my 3 minute investigation, it seems there is something not working
right with the layer z-index.
A polygon can be entered, but it is not rendered till later when you
navigate.
"Select polygon" doesn't select the polygon, but instead the pan control
is activated when you click/drag.
Have you raised a TRAC issue? If not could you please do so.
Eric Lemoine wrote:
> On 4/26/07, Eric Lemoine <Eric.Lemoine at camptocamp.com> wrote:
>> Hi,
>> I've just switched to Ubuntu Feisty, which comes with Firefox 2.0.0.3.
>> So far, life is sweet. Life gets harder when you point your browser to
>> <http://www.openlayers.org/dev/examples/select-feature.html>. You
>> cannot draw a polygon. Actually the polygon gets drawn but it doesn't
>> get displayed. If I go to another FF tab and come back the polygon is
>> displayed! The "select polygon on click" and "select polygon on hover"
>> do not work at all.
>> It sounds like an SVG issue!
>> Is anyone able to reproduce the problem?
> The problem is FF Feisty-specific. FF 2.0.0.3 from mozilla.org doesn't
> have any problem.
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
More information about the Dev
