[OpenLayers-Dev] select-feature.html on FF 2.0.0.3
Eric Lemoine Eric.Lemoine at camptocamp.com
Thu May 3 00:42:25 EDT 2007
Hi Cameron,
I've added a comment to an existing, possibly related, bug.
<https://bugs.launchpad.net/ubuntu/+source/firefox/+bug/88320>.
Thanks,
On 5/3/07, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> Yes Eric, I can confirm that I have the same problems on Ubuntu with the
> same configuration.
> Interesting, there are no JS errors.
>  From my 3 minute investigation, it seems there is something not working
> right with the layer z-index.
> A polygon can be entered, but it is not rendered till later when you
> navigate.
> "Select polygon" doesn't select the polygon, but instead the pan control
> is activated when you click/drag.
> Have you raised a TRAC issue? If not could you please do so.
> Eric Lemoine wrote:
> > On 4/26/07, Eric Lemoine <Eric.Lemoine at camptocamp.com> wrote:
> >> Hi,
> >> I've just switched to Ubuntu Feisty, which comes with Firefox 2.0.0.3.
> >> So far, life is sweet. Life gets harder when you point your browser to
> >> <http://www.openlayers.org/dev/examples/select-feature.html>. You
> >> cannot draw a polygon. Actually the polygon gets drawn but it doesn't
> >> get displayed. If I go to another FF tab and come back the polygon is
> >> displayed! The "select polygon on click" and "select polygon on hover"
> >> do not work at all.
> >> It sounds like an SVG issue!
> >> Is anyone able to reproduce the problem?
> > The problem is FF Feisty-specific. FF 2.0.0.3 from mozilla.org doesn't
> > have any problem.
> Cameron Shorter
> Systems Architect, http://lisasoft.com.au
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
