[OpenLayers-Dev] select-feature.html on FF 2.0.0.3
Cameron Shorter
cameron.shorter at gmail.com
Thu May 3 01:23:20 EDT 2007
Eric,
Good that you have tracked down the Ubuntu/Firefox issue, but we
probably should be tracking in the OL issue tracker too.
Ideally we should introduce a work around in OL as we don't want to tell
all Ubuntu users to go install Windows and wait until the next Ubuntu
release.
Eric Lemoine wrote:
> Hi Cameron,
> I've added a comment to an existing, possibly related, bug.
> <https://bugs.launchpad.net/ubuntu/+source/firefox/+bug/88320>.
> Thanks,
> On 5/3/07, Cameron Shorter <cameron.shorter at gmail.com> wrote:
>> Yes Eric, I can confirm that I have the same problems on Ubuntu with the
>> same configuration.
>> Interesting, there are no JS errors.
>> From my 3 minute investigation, it seems there is something not working
>> right with the layer z-index.
>> A polygon can be entered, but it is not rendered till later when you
>> navigate.
>> "Select polygon" doesn't select the polygon, but instead the pan control
>> is activated when you click/drag.
>> Have you raised a TRAC issue? If not could you please do so.
>> Eric Lemoine wrote:
>> > On 4/26/07, Eric Lemoine <Eric.Lemoine at camptocamp.com> wrote:
>> >> Hi,
>> >> I've just switched to Ubuntu Feisty, which comes with Firefox
>> 2.0.0.3.
>> >> So far, life is sweet. Life gets harder when you point your
>> browser to
>> >> <http://www.openlayers.org/dev/examples/select-feature.html>. You
>> >> cannot draw a polygon. Actually the polygon gets drawn but it doesn't
>> >> get displayed. If I go to another FF tab and come back the polygon is
>> >> displayed! The "select polygon on click" and "select polygon on
>> hover"
>> >> do not work at all.
>> >> It sounds like an SVG issue!
>> >> Is anyone able to reproduce the problem?
>> > The problem is FF Feisty-specific. FF 2.0.0.3 from mozilla.org doesn't
>> > have any problem.
>> Cameron Shorter
>> Systems Architect, http://lisasoft.com.au
>> Tel: +61 (0)2 8570 5050
>> Mob: +61 (0)419 142 254
Cameron Shorter
More information about the Dev
