[OpenLayers-Dev] popups.html example
Christopher Schmidt
crschmidt at metacarta.com
Fri May 4 09:47:24 EDT 2007
On Fri, May 04, 2007 at 07:46:18AM -0500, Les Szklanny wrote:
> Christopher Schmidt wrote:
> >On Mon, Apr 09, 2007 at 08:12:46AM -0500, Les Szklanny wrote:
> >>BTW the 2.4 RC1 examples don't display the map in Safari, so I think
> >>there's a problem with this browser.
> >Safari doesn't like the non-single file version of OpenLayers -- there
> >doesn't seem to be a way to delay execution of the script long enough to
> >let everying load. I've not yet had problems with Safari opening
> >applications using the single file build, which is what we recommend for
> >production use.
> >Regards,
> I just tried RC3 on Safari 1.3.2... multiple and single file
> version...it will not display the map... so there's a problem.
I need more information. I just tested on Safari 2 here, loading
http://openlayers.org/dev/examples/lite.html , and it works fine. Can
you look in the Safari debug menu for errors?
To enable the Javascript console, first you must enable Safariâs
debug menu. Do this by opening your Terminal and inputting this line:
defaults write com.apple.Safari IncludeDebugMenu 1
""" -- http://blog.deconcept.com/2005/07/28/safaris-hidden-debug-menu/
THen turn on 'Log JavaScript Exceptions', relaod the page, and hit 'Show
JavaScript Console', and see if there's anything interesting related t
OpenLayers in there.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
