[OpenLayers-Dev] Safari problem
Les Szklanny
lszklanny at where2getit.com
Fri May 4 10:26:50 EDT 2007
>>> I need more information. I just tested on Safari 2 here, loading
http://openlayers.org/dev/examples/lite.html , and it works fine. Can
you look in the Safari debug menu for errors?
The above link doesn't work in Safari 1.3.2... map is not displayed.
Thanks for the cool debugging tip.
I see this error in the JavaScript Console repeated ~100 times:
TypeError - Value undefined (result of expression arguments[i].hasOwnProperty) is not object.
http://openlayers.org/dev/lib/OpenLayers/BaseTypes.js
Line: 35
Thx,
Les Szklanny
More information about the Dev
