[OpenLayers-Dev] Safari problem
Christopher Schmidt
crschmidt at metacarta.com
Fri May 4 10:50:13 EDT 2007
On Fri, May 04, 2007 at 09:26:50AM -0500, Les Szklanny wrote:
> >>> I need more information. I just tested on Safari 2 here, loading
> http://openlayers.org/dev/examples/lite.html , and it works fine. Can
> you look in the Safari debug menu for errors?
> The above link doesn't work in Safari 1.3.2... map is not displayed.
> Thanks for the cool debugging tip.
> I see this error in the JavaScript Console repeated ~100 times:
> TypeError - Value undefined (result of expression arguments[i].hasOwnProperty) is not object.
> http://openlayers.org/dev/lib/OpenLayers/BaseTypes.js
Okay, that's definitely a blocker for a 2.4 release. I'll open a ticket
for investigation. Thanks.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
