[OpenLayers-Dev] Safari problem
Christopher Schmidt crschmidt at metacarta.com
Wed May 9 21:50:19 EDT 2007
On Fri, May 04, 2007 at 10:50:13AM -0400, Christopher Schmidt wrote:
> On Fri, May 04, 2007 at 09:26:50AM -0500, Les Szklanny wrote:
> > >>> I need more information. I just tested on Safari 2 here, loading
> > http://openlayers.org/dev/examples/lite.html , and it works fine. Can
> > you look in the Safari debug menu for errors?
> > The above link doesn't work in Safari 1.3.2... map is not displayed.
> > Thanks for the cool debugging tip.
> > I see this error in the JavaScript Console repeated ~100 times:
> > TypeError - Value undefined (result of expression arguments[i].hasOwnProperty) is not object.
> > http://openlayers.org/dev/lib/OpenLayers/BaseTypes.js
Can you (or anyone else with Safari 1.3 -- OS X 10.3) try to load
http://dev.openlayers.org/sandbox/crschmidt/bt-patch/examples/lite.html
and let me know if it works?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
