[OpenLayers-Dev] Safari problem
Les Szklanny
lszklanny at where2getit.com
Thu May 10 08:07:13 EDT 2007
Christopher Schmidt wrote:
> On Fri, May 04, 2007 at 10:50:13AM -0400, Christopher Schmidt wrote:
>> On Fri, May 04, 2007 at 09:26:50AM -0500, Les Szklanny wrote:
>>>>>> I need more information. I just tested on Safari 2 here, loading
>>> http://openlayers.org/dev/examples/lite.html , and it works fine. Can
>>> you look in the Safari debug menu for errors?
>>> The above link doesn't work in Safari 1.3.2... map is not displayed.
>>> Thanks for the cool debugging tip.
>>> I see this error in the JavaScript Console repeated ~100 times:
>>> TypeError - Value undefined (result of expression arguments[i].hasOwnProperty) is not object.
>>> http://openlayers.org/dev/lib/OpenLayers/BaseTypes.js
> Can you (or anyone else with Safari 1.3 -- OS X 10.3) try to load
> http://dev.openlayers.org/sandbox/crschmidt/bt-patch/examples/lite.html
> and let me know if it works?
> Regards,
Yes, I can see the map now :)
Thx,
Les Szklanny
Where2GetIt
More information about the Dev
