[OpenLayers-Dev] Bug in OpenLayers.Layer.Vector ?
Christopher Schmidt
crschmidt at metacarta.com
Fri May 11 07:33:00 EDT 2007
On Fri, May 11, 2007 at 01:25:48PM +0200, Christine Spietz wrote:
> Hi guys,
> there seems to be a bug (?) in OpenLayers.Layer.Vector.
> Function getFeatureById(fid) seems not to work properly.
ID != fid
> If I select a Feature in the Vector-layer I am able to alert the fid.
> If I try to get the feature with the alerted fid by
> feature = myVectorLayer.getFeatureById(fid);
> alert("feature = "+feature);
> feature is null.
Yes. The property that getFeatureById is searching for is the 'id'
property, not the 'fid' property.
> Any ideas how to solve this?
there is not currently a getFeatureByFid property -- you will need to
iterate over the layer features, and look for the .fid property.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
