[OpenLayers-Dev] EPSG:41001
Christopher Schmidt crschmidt at metacarta.com
Thu May 24 11:17:45 EDT 2007
On Thu, May 24, 2007 at 11:07:56AM -0400, Gilbert, Antoine wrote:
> For example a tile 256x256 is assumed to have long lat ratio 1x1, but in
> a map using 41001 this long lat ratio does not make a square. That's why
> I don't understand the 1x1 concept
> Here is an example of URL I build with the bounds
> http://localhost:8084/TestOpenLayersWithPNS/ImageServlet?width=256&heigh
> t=256&bbox=-71.267246,46.846768,-71.25626,46.857754
> Here is my javascript/html
You didn't set your resolution. maxResolution should be set to something
sane for the projection you are using, like 156543 .
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
