[OpenLayers-Dev] XML parsing, SLD parsing
Andreas Hocevar andreas.hocevar at gmail.com
Mon Nov 5 15:53:39 EST 2007
Tim,
On 11/5/07, Tim Schaub <tschaub at openplans.org> wrote:
> Guess my question was - where do you need node.text or node.textContext
> instead of using the standard node.nodeValue?
Ah, now you're talking! The reason is that in CSS, two ways of
defining properties are common:
(1)
<CssParameter name="myParam">myValue</CssParameter>
(2)
    <ogc:Literal>myValue</ogc:Literal>
</CssParameter>
To check for both with one statement, I use text || textContent.
Is this ok, or would you rather see a fallback if ogc:Literal is not found?
Regards,
Andreas.
More information about the Dev mailing list
