[OpenLayers-Dev] KML overlays over Google Maps broken?
Chris Whitney
chris.whitney at gmail.com
Sat Nov 3 18:05:27 EDT 2007
When I try to put a KML overlay over a Google Maps base layer, the KML will
"jump around" on the map. This error does not occur when a WMS is the base
layer.
For an example:
http://cwsquared.net/map/test.html
A yellow 3-sided square should appear on that map (bounded by +/- 40
degrees). If the Metacarta WMS (vmap0) is the base layer, it works
properly. However, one of the Google Maps layers is selected, the KML will
move around as the map is zoomed or panned. The bug appears in both Firefox
and Safari.
I tried searching the bug tracker, but did not find any relevant reported
bugs. Should this be reported?
-- Chris Whitney
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20071103/c4fa57bd/attachment.html
More information about the Dev
