[OpenLayers-Dev] createLiteral benchs
    Tim Schaub
    tschaub at openplans.org
    Fri Nov  9 14:30:16 EST 2007
Hey-
This sounds cool.  If you're doing what I think you're doing, perhaps
this could be moved to the OpenLayers.String namespace.
The function could have a signature like:
/*{String}*/ OpenLayers.String.format(/*{String}*/ template,
/*{Object}*/ context);
If that sounds right, see if http://trac.openlayers.org/ticket/1133 does
what you want it to.
Tim
Andreas Hocevar wrote:
> Hi,
> I added a new method to [1]. It is faster than andreas' method 2, and
> has the same scaling characteristics. I also changed
> OpenLayers.Style.createLiteral to use this new method.
> Regards,
> Andreas.
> [1] http://dev.openlayers.org/sandbox/ahocevar/sldRenderer/examples/profilingAttributeName.html
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
> !DSPAM:4033,4732069d6402458217002!
More information about the Dev
