[OpenLayers-Dev] problem resizing overview map container
Val Cartei
val.cartei at gmail.com
Tue Nov 27 10:51:18 EST 2007
I am trying to create a control that dynamically resizes the OverviewMap.
I got as far as adding the resizing functionality and the handle, but when I
resize, for some reason the image gets bigger until a certain point and then
stops.
http://dev.getconveyor.org/panorama_experiments/31/
Ideally it should be that as I resize the container, the dimensions of ovmap
change to fill it and the rectangle within the overviewmap gets updated
accordingly.
Alternatively, there should be a set of available scales the user can choose
from, but when I added the Scale control to ovmap, nothing seemed to happen.
If you have any ideas, that'd be great coz I am completely stuck!
Val
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20071127/6129c1db/attachment.html
More information about the Dev
