[OpenLayers-Dev] WMS GetCapabilities Requst
Ganesh Jothikumar
ganeshjothikumar at yahoo.com
Tue Nov 27 12:47:56 EST 2007
Hi Lorenzo
Thank you very much for the help. I have a question. Is there a way I can directly get the bounding box values for a layer using WMS Manager APIs. Because the reason I want to do WMS GetCapabilities is to get this info only. If WMS GetCapabilities is the only way then I am not sure how to do it using WMS Manager. Can you show me with an example ( making a WMS GetCapabilities to a WMS server request and after parsing the received XML ). Any help is highly appreciated
Thanks in advance
ganesh
----- Original Message ----
To: Ganesh Jothikumar <ganeshjothikumar at yahoo.com>
Cc: rldhont <rldhont at gmail.com>; dev at openlayers.org
Sent: Tuesday, 27 November, 2007 1:53:12 AM
Subject: Re: [OpenLayers-Dev] WMS GetCapabilities Requst
Hi Ganesh,
I've made an external module for OpenLayers that does what you want (maybe).
The name is WMS Manager [1].
There's a blog post that explain how to use it in the easy way [2].
there's a live application the shows it working [3].
The code is not that clean but inside the WMS Manager Control there are
a few tricks to make GetCapabilities work smoothly with Mapserver and
Geoserver, and some other WMS servers. Not all vendors are supported. I
consider this code still in Beta phase; I'm still developing new
features that I need for my project.
I'll be available for further explanations.
ciao
Lorenzo
[1] http://www.ominiverdi.org/index.php/openlayers
[2]
http://blog.ominiverdi.org/index.php?/archives/21-WMS-Manager-on-OpenLayers.html
[3]
http://www.ominiverdi.org/openlayers/sandbox/openlayers/examples/wms_manager_abs.html
Ganesh Jothikumar wrote:
> Hi rldhont
> Thanks for the reply. yes I am aware of the XML format.
> And thanks for the example also. But what I want is how to make the
> /*WMS GetCapabilities*/ request from Java Script using the OL APIs. It
> will be very helpfult if someone could help me with a few lines of code..
> Thanks
> ganesh
> From: rldhont <rldhont at gmail.com>
> To: dev at openlayers.org
> Sent: Monday, 26 November, 2007 7:18:10 PM
> You can use XML Format. Look at the source code of this example :
> http://openlayers.org/dev/examples/xml.html
> René-Luc D'Hont
> 3Liz SARL
> blog: http://3liz.org/blog/rldhont
> Ganesh Jothikumar a écrit :
> > Hi All
> > I am using OpenLayers with GeoServer. I am using OpenLayers
> > JavaScript APIs to render the WMS layers present in GeoServer. Of the
> > layers I have one base layer and multiple overlays. Now I need to
> > specify the bounding box values for the base map coverage layer in the
> > OpenLayers.WMS function (maxExtent : bounds ) For thst I need to get
> > the values from the GeoServer. After consulting the GeoServer guys I
> > came to know that I have to do a WMS GetCapabilities request and parse
> > the returned XML to get the BBox for my layer. What I want to know is
> > how to make a WMS GetCapabilities request using OpenLayers and parse
> > the returned XML. Any example would be highly useful. Or let me know
> > if there is any other way of solving this...
> > Thanks in advance
> > ganesh
> > Why delete messages? Unlimited storage is just a click away.
> <http://in.rd.yahoo.com/tagline_mail_1/*http://help.yahoo.com/l/in/yahoo/mail/yahoomail/tools/tools-08.html/>
> > Dev mailing list
> > Dev at openlayers.org <mailto:Dev at openlayers.org>
> > http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
> Bring your gang together - do your thing. Start your group.
> <http://in.rd.yahoo.com/tagline_groups_2/*http://in.promos.yahoo.com/groups>
> Dev mailing list
Bring your gang together - do your thing. Go to http://in.promos.yahoo.com/groups
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20071127/6cd80cde/attachment.html
More information about the Dev
