[OpenLayers-Dev] coding style best practices
Paul Spencer
pspencer at dmsolutions.ca
Mon Oct 1 16:28:15 EDT 2007
I am not a particularly fastidious coder but I do strongly believe
that folks should be making their code readable and, as much as
possible, avoid common sources of bugs. Also, for those folks
looking to make contributions, it is going to be much easier for the
core maintainers to bring your code into trunk if it already fits the
coding style of OpenLayers.
I am sure Chris will have more to say on this, but my particular pet
peeves are:
1. Not using { } around code associated with if statements. For
instance, it is legal in javascript to write the following:
if (foo)
return true
Lets say you need to do one more thing in this case, increment foo:
if (foo)
foo++
return true
This will no longer work as expected (its not python!). I highly
recommend using brace brackets around all conditionals.
2. Not using whitespace to make code readable:
if(foo<2||foo>5)return foo+12
else if(foo>7)return foo-1
else return foo
should be:
if (foo < 2 || foo > 5) {
return foo + 12;
} else if (foo > 7) {
return foo - 1;
} else {
return foo;
or some variant of this. The code compressor can make it unreadable
later. Right now, I need to be able to understand the code when
reviewing it!
Cheers
Paul
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the Dev
