[OpenLayers-Dev] VML Rendering of point data
fporc7ji fporcelli at taic.net
Mon Oct 1 17:01:00 EDT 2007
It's very strange that this is only happening in my dev environment.
I'll have to assume it's something on my end.
Thanks for checking.
Regards,
Frank
Christopher Schmidt-4 wrote:
> On Mon, Oct 01, 2007 at 01:32:23PM -0700, fporc7ji wrote:
>> Hi Chris --
>> I've attached a zip file containing screen shots of what my output looks
>> like when viewing the example in both Firefox and IE6. Notice that the
>> IE6
>> output shows the points skewed to the right (IE6 has FF points in Florida
>> located in Cuba and Maryland's are in the Atlantic. The further east you
>> go,
>> the farther off the points are.
> Your attachment didn't get through, but I'm definitely not seeing this.
> Can you try installing IE7 (or finding someone with it) and seeing if
> this changes things?
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
http://www.nabble.com/file/p12987707/KML-IE6.jpg
View this message in context: http://www.nabble.com/VML-Rendering-of-point-data-tf4516302.html#a12987707
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
