[OpenLayers-Dev] singleTile optimization
Stephen Woodbridge woodbri at swoodbridge.com
Wed Oct 3 22:37:29 EDT 2007
pspencer at dmsolutions.ca wrote:
> What do you think about aligning singleTile bounds to the grid to
> promote cacheability in the client?
I think that this should be an option in the layer definition if it gets
done. I can see some benefits to doing this, but the down side is that
all images generated will be larger and slower to generate and the
singleTile option needs to support more than one use case in my mind anyway.
-Steve
More information about the Dev mailing list
