[OpenLayers-Dev] Code Sprint: SLD
Andreas Hocevar
andreas.hocevar at gmail.com
Wed Oct 3 22:38:34 EDT 2007
I'm sorry Cameron, I totally forgot mentioning your help at the code
sprint. Thank you!
Alex, have you tried to get the latest version of the sandbox for the
Tasmania test set? Because after the code sprint, calculating the
correct style for a feature was done using eval(). Meanwhile, I
changed this, and Firebug Profiler shows no significant delay in
rendering features with the sld.xml test file from the sandbox.
It would be interesting to get some profiling/performance report from
you, with the latest version from the ahocevar/sldRenderer sandbox.
Regards,
Andreas.
On 10/3/07, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> Of note:
> During the code sprint I helped to start building sample ogc:filters for
> the style. (Actually, I only built one)
> The next step I discussed with Andreas was to use a standard GML test
> set which I recommend should be the Tasmania GML used by Geoserver and
> Mapbuilder.
> Alex Djioev from Lisasoft did a little work on this yesterday and I
> expect he will be committing to Andreas's sandbox soon.
> Of interest and possible concern is that rendering seemed to be
> noticeably slower with the slightly larger Tasmania dataset. This
> dataset is still reasonably small by vector standards and we might need
> to consider ways to optimize.
More information about the Dev
