[OpenLayers-Dev] singleTile optimization
David William Bitner
david.bitner at gmail.com
Thu Oct 4 09:36:16 EDT 2007
Ducky!
Great to see you here -- don't be a stranger.
The problem with aligning singleTile to a grid is that as soon as you have
the corner of the grid on the screen, all the sudden you are in a tiled mode
only with larger tiles. It strikes me that for any use case that would
require any kind of grid alignment at all, really you should be using a
tiled mode only with perhaps larger tiles and smaller buffers. The use case
that I see for single tile is for dynamic data -- data that is dynamic
enough that you wouldn't want it cached at all, ever.
David
On 10/4/07, Dan Little <danlittle at yahoo.com> wrote:
> Yikes, first time poster!
> I think the speed to generate a single tile is wholely dependent on the
> map-rendering engine and the dataset.
> For example, here at the City of Saint Paul, our streets layer is entirely
> vector. I can generate a very very large tile with highly detailed streets
> for the entire city using Mapserver in less than 1/3 of a second. Given the
> nature of MapServer, and the size of the shapefile which stores our streets
> layer, multiple tiles is much much slower (as the shapefile needs to be read
> from disk and loaded to memory for each rendered tile). It would be nice to
> have some of the effects of tiling without the high-cost it currently
> presents in rendering performance.
> Dan "Ducky" Little
> City of Saint Paul / Public Works / GIS
> ----- Original Message ----
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> To: pspencer at dmsolutions.ca
> Cc: dev at openlayers.org
> Sent: Wednesday, October 3, 2007 9:37:29 PM
> Subject: Re: [OpenLayers-Dev] singleTile optimization
> pspencer at dmsolutions.ca wrote:
> > What do you think about aligning singleTile bounds to the grid to
> > promote cacheability in the client?
> I think that this should be an option in the layer definition if it gets
> done. I can see some benefits to doing this, but the down side is that
> all images generated will be larger and slower to generate and the
> singleTile option needs to support more than one use case in my mind
> anyway.
> -Steve
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
> Luggage? GPS? Comic books?
> Check out fitting gifts for grads<http://us.rd.yahoo.com/evt=48249/*http://search.yahoo.com/search?fr=oni_on_mail&p=graduation+gifts&cs=bz>at Yahoo! Search.
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20071004/bf8bc7e3/attachment.html
More information about the Dev
