[OpenLayers-Dev] SVG line rendering bug on pan
Christopher Schmidt
crschmidt at metacarta.com
Fri Oct 12 14:08:54 EDT 2007
On Fri, Oct 12, 2007 at 10:41:46AM -0700, Andre Lockhart wrote:
> I am working on an application where I am drawing lines over a map using the
> OL SVG graphics API.
What browser are you in? IE? (In that case, it's actually VML, not SVG.)
Can you reproduce it on the examples?
I think this might be fixed by http://trac.openlayers.org/ticket/965 --
I think this is the same general problem, but possibly not exactly the
same one.
> Where in the source code would we go to fix this bug?
Probably in the Renderer/* Classes.
> I didn't see an open bug on this, so how do I get it logged?
http://trac.openlayers.org/wiki/FilingTickets
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
