[OpenLayers-Dev] jslint results
Erik Uzureau erik.uzureau at metacarta.com
Tue Oct 16 14:52:32 EDT 2007
Also, It would probably be good to somehow incorporate these into:
http://trac.openlayers.org/wiki/CodingStandards
e
On 10/16/07, Erik Uzureau <erik.uzureau at metacarta.com> wrote:
> Dear Paul,
> I approve of each and every one of the numbered resolutions you
> suggest herebelow. They will all contribute to a more standardized,
> consistent, readable codebase.
> You have my +1
> Erik
> On 10/16/07, Paul Spencer <pspencer at dmsolutions.ca> wrote:
> > Thanks Erik.  Before I go ahead and make a bunch of changes, though,
> > I'd like some feedback on how pedantic we should be about certain
> > coding practices.  I'd like feedback from the core devs on the
> > following things:
> > 1) use of semi-colons
> > Should we care about certain edge cases, such as:
> > var f = function(){return true};
> > will say that you need a semi-colon after true (inside the block
> > scope of the function)
> > 2) use of curly braces around block scope
> > Should we care about one line cases and implied scope, such as:
> > if (this.singleLayer) return;
> > for (var i=0; i<this.grid.length; i++)
> >      if (this.grid[i].length) {
> > 3) unreachable code
> > function foo() {
> >      return true;
> >      var test = 1;
> > 4) missing break statements, missing break in last case of switch
> > 5) leading or trailing decimal points
> > .000
> > 000.
> > 6) nested comments
> > /* comment
> > There are quite a few more options that can be used too, but are
> > disabled by default because they have more of an impact on coding style.
> > I personally like the ones above because they are situations that can
> > lead to erroneous code in a multi-developer environment.
> > I am also not advocating that we fix every warning that comes out of
> > the tool, but rather that it can help us focus on specific potential
> > problem areas - i.e. not using break statements in a switch is a
> > reasonable technique in some instances.
> > Please give me feedback on whether you want me to vet the code for
> > the above issues or not.  I will make a single commit with all the
> > changes on the current trunk once it is decided what we should or
> > shouldn't include.  Thereafter, I will check trunk occasionally,
> > especially before we cut a release, and do touch ups as required.
> > Cheers
> > Paul
> > > As a core committer, you should feel free to make these changes as you
> > > see fit. OpenLayers has a (somewhat unstated) policy that
> > > non-functional patches need not go through the standard
> > > ticket/approval system.
> > > ...which means that if you want to replace a missing semicolon or tab
> > > out a line or add a comment or something like that, you should just go
> > > ahead and do it. As long as it doesn't change the functioning of the
> > > code.
> > > Erik
> > > ps. thanks so much for taking the time to run this analysis. Looks
> > > like our code has not a few little oversights!
> > >> The regular expression one I am not so sure about.  Anyone know
> > >> anything about javascript syntax in this particular case?
> > >> Cheers
> > >> Paul
> > >> |Paul Spencer                          pspencer at dmsolutions.ca    |
> > >> |Chief Technology Officer                                         |
> > >> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
> > >> _______________________________________________
> > >> Dev mailing list
> > >> Dev at openlayers.org
> > >> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
