[OpenLayers-Dev] jslint results
Tim Schaub
tschaub at openplans.org
Tue Oct 16 16:59:53 EDT 2007
Agreed. These are all good practices.
I'd be glad to see them become part of our coding standards.
Tim
Erik Uzureau wrote:
> Dear Paul,
> I approve of each and every one of the numbered resolutions you
> suggest herebelow. They will all contribute to a more standardized,
> consistent, readable codebase.
> You have my +1
> Erik
> On 10/16/07, Paul Spencer <pspencer at dmsolutions.ca> wrote:
>> Thanks Erik. Before I go ahead and make a bunch of changes, though,
>> I'd like some feedback on how pedantic we should be about certain
>> coding practices. I'd like feedback from the core devs on the
>> following things:
>> 1) use of semi-colons
>> Should we care about certain edge cases, such as:
>> var f = function(){return true};
>> will say that you need a semi-colon after true (inside the block
>> scope of the function)
>> 2) use of curly braces around block scope
>> Should we care about one line cases and implied scope, such as:
>> if (this.singleLayer) return;
>> for (var i=0; i<this.grid.length; i++)
>> if (this.grid[i].length) {
>> 3) unreachable code
>> function foo() {
>> return true;
>> var test = 1;
>> 4) missing break statements, missing break in last case of switch
>> 5) leading or trailing decimal points
>> .000
>> 000.
>> 6) nested comments
>> /* comment
>> There are quite a few more options that can be used too, but are
>> disabled by default because they have more of an impact on coding style.
>> I personally like the ones above because they are situations that can
>> lead to erroneous code in a multi-developer environment.
>> I am also not advocating that we fix every warning that comes out of
>> the tool, but rather that it can help us focus on specific potential
>> problem areas - i.e. not using break statements in a switch is a
>> reasonable technique in some instances.
>> Please give me feedback on whether you want me to vet the code for
>> the above issues or not. I will make a single commit with all the
>> changes on the current trunk once it is decided what we should or
>> shouldn't include. Thereafter, I will check trunk occasionally,
>> especially before we cut a release, and do touch ups as required.
>> Cheers
>> Paul
>>> As a core committer, you should feel free to make these changes as you
>>> see fit. OpenLayers has a (somewhat unstated) policy that
>>> non-functional patches need not go through the standard
>>> ticket/approval system.
>>> ...which means that if you want to replace a missing semicolon or tab
>>> out a line or add a comment or something like that, you should just go
>>> ahead and do it. As long as it doesn't change the functioning of the
>>> code.
>>> Erik
>>> ps. thanks so much for taking the time to run this analysis. Looks
>>> like our code has not a few little oversights!
>>>> The regular expression one I am not so sure about. Anyone know
>>>> anything about javascript syntax in this particular case?
>>>> Cheers
>>>> Paul
>>>> |Paul Spencer pspencer at dmsolutions.ca |
>>>> |Chief Technology Officer |
>>>> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
> !DSPAM:4033,47150847104772085621377!
More information about the Dev
