[OpenLayers-Dev] Addins Directory
Paul Spencer
pspencer at dmsolutions.ca
Thu Oct 18 08:42:15 EDT 2007
Erik,
are the Addins intended to be officially supported, but outside the
core library? Or are they intended to be third party contributions
that are 'use at your own risk'?
If it is the second case, I would rather see the addins directory be
at the root level like sandboxes rather than within trunk.
Cheers
Paul
On 17-Oct-07, at 4:00 AM, Erik Uzureau wrote:
> Since Señor Schmidt has been so good about carrying the new ClearBSD
> license forward[1], the time has come once again to talk about the
> idea of an Addins directory.
> The idea behind Addins is to create a space in the OpenLayers
> repository where we can put layers, controls, and other OpenLayers
> related projects that don't quite belong in the core distribution of
> the library, but that people might find useful.
> The hope with Addins is that it will be a fertile ground for people to
> show off tricks and gadgets they've built that do cool things with
> OpenLayers and that they're interested to give back to the community.
> Off the top of my head, a couple of specific projects seem like worthy
> candidates:
> * WMS Manager (getCapabilities-enhanced layerswitcher tool)
> * Generally Improved LayerSwitcher (grouping, dragging-to-reorder)
> * Driving Directions library (code that works with OLS or pgRouting
> to request and display routing information on an OpenLayers Map)
> I'm sure there are many other projects that could qualify.
> It is important to distinguish between the sandboxes and the Addins
> directory. The former is a playground for people to experiment. The
> code is not covered by any license and is indeed in a sort of
> "free-for-all" state. The latter, however, will be exclusively for
> established projects interested in a more formal release process. Code
> in the Addins directory will be covered under the ClearBSD license,
> and tags will be made for compatibility with different OL versions.
> A proposed directory structure might look something like this:
> /sandbox
> /branches
> /trunk
> /trunk/openlayers
> /trunk/addins
> /tags/openlayers
> /tags/addins
> Please let me know what you think of this proposal, and if you think
> you have a project that you would be interested in releasing in the
> Addins directory.
> Cheers, boa noite,
> Erik
> [1] http://trac.openlayers.org/changeset/4985
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the Dev
